Linear algebra algorithms in a heterogeneous cluster of personal computers, 9th Heterogeneous Computing Workshop (HCW'2000), pp.147-159, 2000. ,
A proposal for a heterogeneous cluster ScaLAPACK (dense linear solvers), IEEE Trans. Computers, vol.50, issue.10, pp.1052-1070, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00808287
Matrix multiplication on heterogeneous platforms, IEEE Trans. Parallel Distributed Systems, vol.12, issue.10, pp.1033-1051, 2001. ,
DOI : 10.1109/71.963416
URL : https://hal.archives-ouvertes.fr/hal-00808288
, LP SOLVE: Linear Programming Code
High-performance schedulers, The Grid: Blueprint for a New Computing Infrastructure, pp.279-309, 1999. ,
High Performance Cluster Computing, Architecture and Systems, vol.1, 1999. ,
Compile-time scheduling algorithms for heterogeneous network of workstations, The Computer Journal, vol.40, issue.6, pp.356-372, 1997. ,
Customized dynamic load balancing for a network of workstations, Journal of Parallel and Distributed Computing, vol.43, pp.156-162, 1997. ,
Introduction to Algorithms, 1990. ,
Block data decomposition for data-parallel programming on a heterogeneous workstation network, 2nd International Symposium on High Performance Distributed Computing, pp.42-49, 1993. ,
Class notes, Linear Optimisation and Numerical Analysis, Mathematical Sciences ,
Parallel Computer Architecture: A Hardware/Software Approach, 1999. ,
Dynamic load balancing in parallel discrete event simulation for spatially explicit problems, PADS'98, 12th Workshop on Parallel and Distributed Simulation, pp.46-53, 1998. ,
Parametric integer programming, RAIRO Recherche Opérationnelle, vol.22, pp.243-268, 1988. ,
Résolution de systèmes d'inéquations linéaires; mode d'emploi du logiciel PIP, 1990. ,
, The Grid: Blueprint for a New Computing Infrastructure, 1999.
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1991. ,
An effective implementation of the Lin-Kernighan traveling salesman heuristic, European Journal of Operational Research, vol.126, issue.1, pp.106-130, 2000. ,
Load balancing for unstructured mesh applications. Parallel and Distributed Computing Practices, vol.2, 1999. ,
Static load balancing of parallel PDE solver for distributed computing environment, PDCS'2000, 13th Int'l Conf. Parallel and Distributed Computing Systems, pp.399-405, 2000. ,
Array decomposition for nonuniform computational environments, Journal of Parallel and Distributed Computing, vol.36, pp.91-105, 1996. ,
Heterogeneous distribution of computations while solving linear algebra problems on networks of heterogeneous computers, LNCS, vol.1593, pp.191-200, 1999. ,
An effective heuristic algorithm for the traveling salesman problem, Operations Research, vol.21, pp.498-516, 1973. ,
Optimal dynamic remapping of data parallel computations, IEEE Trans. Computers, vol.39, issue.2, pp.206-219, 1990. ,
Dynamic remapping of parallel computations with varying resource demands, IEEE Trans. Computers, vol.37, issue.9, pp.1073-1087, 1988. ,
Scheduling and load balancing in parallel and distributed systems, 1995. ,
A practical approach to dynamic load balancing, IEEE Trans. Parallel and Distributed Systems, vol.9, issue.93, pp.235-248, 1998. ,
INRIA Unité de recherche INRIA Lorraine, Technopôle de Nancy-Brabois, Campus scientifique, 615 rue du Jardin Botanique, BP 101, 54600 VILLERS L ` ES NANCY Unité de recherche INRIA Rennes, route des Lucioles, vol.8, pp.173-186, 1997. ,
