Component-based engineering of real-time JAVA : applications on a polychronous design platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Rising complexity and performances of embedded systems, shortening time-to-ma- rket demands for digital equipments, growing installed bases of intellectual properties, stress high-level design as a prominent research topic to compensate a widening productivity gap. In this aim, we put the principles of polychronous design (i.e. multi-clocked and synchronous) to work in the context of the real-time Java programming language by introducing a method for modeling, transforming, verifying and simulating multi-threaded real-time Java components in the multi-clocked synchronous data-flow design language Signal. We put this technique to work for the component-based design and refinement of an even-parity checker with communication protocols.
RR-4744.pdf (505.51 Ko) Télécharger le fichier
inria-00071843 , version 1 (23-05-2006)
  • HAL Id : inria-00071843 , version 1
Jean-Pierre Talpin, Bruno Le Dez, Abdoulaye Gamatié, Paul Le Guernic, David Berner. Component-based engineering of real-time JAVA : applications on a polychronous design platform. [Research Report] RR-4744, INRIA. 2003. ⟨inria-00071843⟩
214 Consultations
254 Téléchargements
