Integral Formulations for the EEG Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Maureen Clerc
  • Fonction : Auteur
  • PersonId : 843531
Toufic Abboud
  • Fonction : Auteur
Olivier Faugeras
Renaud  Keriven
  • Fonction : Auteur
Théodore Papadopoulo
The forward electro-encephalography (EEG) problem involves finding a potential V from the Poisson equation (V)=f, in which f represents electrical sources in the brain, and the conductivity of the head tissues. In the piecewise constant conductivity head model, this can be accomplished by the Boundary Element Method (BEM) using a suitable integral formulation. Most previous work is based on the same integral formulation, based on a double-lay- er potential. In this article we detail several alternative possibilities. We present a dual approach which involves a single-layer potential. Finally, we propose a symmetric formulation, which combines single and double-layer potentials, and which is new to the field of EEG, although it has been applied to other problems in electromagnetism. The three methods have been evaluated numerically using a semi-realistic geometry with known analytical solution, and the symmetric method achieves a significantly higher accuracy.
Autre [cs.OH]
RR-4735.pdf (592.55 Ko) Télécharger le fichier
inria-00071852 , version 1 (23-05-2006)
  • HAL Id : inria-00071852 , version 1
Jan Kybic, Maureen Clerc, Toufic Abboud, Olivier Faugeras, Renaud  Keriven, et al.. Integral Formulations for the EEG Problem. RR-4735, INRIA. 2003. ⟨inria-00071852⟩
156 Consultations
334 Téléchargements
