New interface
Reports (Research report)
A Procedural Approach to Style for NPR Line Drawing from 3D models
Stéphane Grabli 1 Frédo Durand 1 Emmanuel Turquin 1 François X. Sillion 1
1 ARTIS - Acquisition, representation and transformations for image synthesis
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : This paper introduces a procedural approach to non-photorealistic line drawing from 3D models. The approach is inspired both by procedural shaders in classical rendering and by the power of procedural modeling. We propose a new image creation model where all operations are controlled procedurally. A view map describing all relevant support lines in the drawing is first created from the 3d model; a number of style modules operate on this map, by procedurally selecting and chaining lines before creating strokes and assigning drawing attributes. Two different levels of user control are provided, ranging from a low-level programming API to a parameteri- zed building-block assembly mechanism. The resulting drawing system allows very flexible control of all elements of drawing style: first, different style modules can be applied to different types of lines in a view; second, stroke attributes are assigned procedurally and can be correlated at will with various scene or view properties. We illustrate the components of our system and show results of its application.
keyword : NPR STYLE LINE DRAWING
Document type :
Complete list of metadata
Cited literature [49 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071862
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:02:32 PM
Last modification on : Thursday, October 27, 2022 - 4:02:47 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:41:38 PM
Identifiers
  • HAL Id : inria-00071862, version 1
Citation
Stéphane Grabli, Frédo Durand, Emmanuel Turquin, François X. Sillion. A Procedural Approach to Style for NPR Line Drawing from 3D models. [Research Report] RR-4724, INRIA. 2003. ⟨inria-00071862⟩
Share
Metrics
Record views
219
Files downloads
1270
