The Paderborn university BSP (PUB) library-design, implementation and performance, Proceedings 13th International Parallel Processing Symposium and 10th Symposium on Parallel and Distributed Processing. IPPS/SPDP 1999, 1999. ,
DOI : 10.1109/IPPS.1999.760442
A bridging model for parallel computation, communication, and I/O, ACM Computing Surveys, vol.28, issue.4, 1996. ,
Efficient external memory algorithms by simulating coarsegrained parallel algorithms, ACM Symposium on Parallel Algorithms and Architectures, pp.106-115, 1997. ,
SCALABLE PARALLEL COMPUTATIONAL GEOMETRY FOR COARSE GRAINED MULTICOMPUTERS, International Journal of Computational Geometry & Applications, vol.06, issue.03, pp.379-400, 1996. ,
DOI : 10.1142/S0218195996000241
PM 2 : Parallel multithreaded machine, un support d'exécution pour applications irrégulières, RenPar 7, 1995. ,
SSCRAP : An environment for coarse grained algorithms, Fourteenth IASTED International Conference on Parallel and Distributed Computing and Systems, 2002. ,
PRO : a model for parallel resource-optimal computation, 16th Annual International Symposium on High Performance Computing Systems and Applications, pp.106-113, 2002. ,
Direct bulk-synchronous parallel algorithms, Journal of Parallel and Distributed Computing, vol.22, issue.2, pp.251-267, 1994. ,
The green BSP library, 1995. ,
Portable list ranking: an experimental study, ACM Journal of Experimental Algorithmics, vol.7, issue.7, 2002. ,
Randomized permutations in a coarse grained parallel environment, Proceedings of the fifteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '03, 2002. ,
DOI : 10.1145/777412.777454
URL : https://hal.archives-ouvertes.fr/inria-00107672
BSPlib : The BSP programming library, 1997. ,
A library for bulk-synchronous parallel programming, British Computer Society Parallel Processing Specialist Group workshop on General Purpose Parallel Computing, 1993. ,
RR n?4719 Unité de recherche INRIA Lorraine Technopôle de Nancy-Brabois, Campus scientifique, 615 rue du Jardin Botanique, Communications of the ACM, vol.33, issue.105, pp.103-111, 1990. ,
