New interface
Reports (Research report)
Perturbation Analysis for Denumerable Markov Chains with Application to Queueing Models
Abstract : We study the parametric perturbation of Markov chains with denumerable state space. We consider both regular and singular perturbations. By the latter we mean that transition probabilities of a Markov chain, which has several ergodic classes, is perturbed in a way that allows rare transitions between the different ergodic classes of the unperturbed chain. In the previous works the singularly perturbed Markov chains were studied under restrictive assumptions such as strong recurrence ergodicity or Doeblin conditions. Our goal is to relax these by conditions that can be applied to queueing models (where the conditions mentioned above typically fail to hold). With the help of the $\nu$-geometric ergodicity approach, we are able to express explicitly the steady state distribution of the perturbed Markov chain as a Taylor series in the perturbation parameter. We apply our tools to quasi birth and death processes and provide queueing examples.
Document type :
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071873
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:04:08 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:32 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:42:14 PM
Identifiers
  • HAL Id : inria-00071873, version 1
Collections
Citation
Eitan Altman, Rudesindo Núñez-Queija, Konstantin Avrachenkov. Perturbation Analysis for Denumerable Markov Chains with Application to Queueing Models. [Research Report] RR-4713, INRIA. 2003. ⟨inria-00071873⟩
Share
Metrics
Record views
95
Files downloads
331
