Minimal enclosing parallelepiped in 3D - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We investigate the problem of finding a minimal volume parallelepiped enclosing a given set of n three-dimensional points. We give two mathematical properties of these parallelepipeds, from which we derive two algorithms of theoretical complexity O(n^6). Experiments show that in practice our quickest algorithm runs in O(n^2) (at least for $n \leq 10^5$n 10^5). We also present our application in structural biology.
Autre [cs.OH]
RR-4685.pdf (461.27 Ko) Télécharger le fichier
RR2002-49.pdf (580.34 Ko) Télécharger le fichier
inria-00071901 , version 1 (23-05-2006)
  • HAL Id : inria-00071901 , version 1
Frédéric Vivien, Nicolas Wicker. Minimal enclosing parallelepiped in 3D. [Research Report] RR-4685, LIP RR-2002-49, INRIA, LIP. 2002. ⟨inria-00071901⟩
107 Consultations
647 Téléchargements
