A reduction semantics for call-by-value mixin modules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Joe B. Wells
  • Fonction : Auteur
Module systems are important for software engineering: they facilitate code reuse without compromising the correctness of programs. However, they still lack some flexibility: first, they do not allow mutually recursive definitions to span module boundaries ; second, definitions inside modules are bound early, and cannot be overridden later, as opposed to inheritance and overriding in class-based object-oriented languages, which follow the late binding semantics. This paper examines an alternative, hybrid idea of modularization concept, called mixin modules. We develop a language of call-by-value mixin modules with a reduction semantics, and a sound type system for it, guaranteeing that programs will run correctly.
Autre [cs.OH]
RR-4682.pdf (434.27 Ko) Télécharger le fichier
inria-00071903 , version 1 (23-05-2006)
  • HAL Id : inria-00071903 , version 1
Tom Hirschowitz, Xavier Leroy, Joe B. Wells. A reduction semantics for call-by-value mixin modules. [Research Report] RR-4682, INRIA. 2002. ⟨inria-00071903⟩
124 Consultations
139 Téléchargements
