New interface
Reports (Research report)
Design of real-time periodic control systems through synchronisation and fixed priorities
Daniel Simon 1 Fanny Benattar 1
1 BIP - Biped Robot
Inria Grenoble - Rhône-Alpes
Abstract : Control systems are often designed using a set of cooperating periodic modules running under control of a real-time operating system. A correct behaviour of the closed-loop controller requires that the system meets timing constraints like periods and latencies, which can be expressed as deadlines. The software uses the fixed priority based preemption service of the operating system. Latencies are controlled through precedence constraints and more or less tight synchronisation between modules. Such a system can be modelled with timed event graphs, and its temporal behaviour can be analysed using the underlying (max,plus) algebra. Examples coming from a uni-processor robot controller are provided.
Document type :
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071908
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:13:23 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:10 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:43:59 PM
Identifiers
  • HAL Id : inria-00071908, version 1
Collections
Citation
Daniel Simon, Fanny Benattar. Design of real-time periodic control systems through synchronisation and fixed priorities. [Research Report] RR-4677, INRIA. 2002. ⟨inria-00071908⟩
Share
Metrics
Record views
78
Files downloads
382
