Experiences Implementing Efficient Java Thread Serialization, Mobility and Persistence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Today, mobility and persistence are important aspects of distributed computing- . They have many fields of use such as load balancing, fault tolerance and dynamic reconfiguration of applications. In this context, Java provides many useful mechanisms for the mobility of code via dynamic class loading, and the mobility or persistence of data via object serialization. However, Java does not provide any mechanism for the mobility/persistence of computation (i.e., threads). We designed and implemented a new mechanism, called , that is used to build thread mobility or thread persistence. Therefore, a running Java thread can, at an arbitrary state of its execution, migrate to a remote machine where it resumes its execution, or be checkpointed on disk for possible subsequent recovery. With our services, migrating a thread is simply performed by the call of our primitive, and checkpointing/recovering a thread is performed by the call of our and primitives. Several projects have recently addressed the issue of Java thread serialization, e.g., Sumatra, Wasp, JavaGo, Brakes, JavaGoX, Merpati. Some of them have attempted to minimize the overhead incurred by the thread serialization mechanism on thread performance, but none of them has been able to completely avoid this overhead. We propose a generic Java thread serialization mechanism that does not impose any performance overhead on serialized threads. This is achieved thanks to the use of type inference and dynamic de-optimization techniques. In this paper, we describe the design and implementation details of our thread serialization prototype in Sun Microsystems' JDK. We report on experiments conducted with our prototype, present a comparative performance evaluation of the main thread serialization techniques, and confirm the elimination of the performance overhead with our thread serialization mechanism.
RR-4662.pdf (996.57 Ko) Télécharger le fichier
inria-00071923 , version 1 (23-05-2006)
  • HAL Id : inria-00071923 , version 1
Sara Bouchenak, Daniel Hagimont, Sacha Krakowiak, Noel de Palma, Fabienne Boyer. Experiences Implementing Efficient Java Thread Serialization, Mobility and Persistence. [Research Report] RR-4662, INRIA. 2002. ⟨inria-00071923⟩
187 Consultations
471 Téléchargements
