Estimating Travel Time in a Single Lane System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Prediction of accurate travel time is an important aspect in real time monitoring of the traffic behavior on a city network. The dynamic traffic flows entering the network affect the behavior of the system and the free flow movement of vehicles. To study the complex system dynamics arising due to varying input flows, we begin with a single lane system. The analysis of the behavior of the system is done to derive the travel time from the characteristics of the lane, the input flow and the constraints on the output flow.
Autre [cs.OH]
RR-4655.pdf (708.27 Ko) Télécharger le fichier
inria-00071930 , version 1 (23-05-2006)
  • HAL Id : inria-00071930 , version 1
Anjali Awasthi, Michel Null Parent, Jean-Marie Proth. Estimating Travel Time in a Single Lane System. [Research Report] RR-4655, INRIA. 2002. ⟨inria-00071930⟩
162 Consultations
335 Téléchargements
