A bridging model for parallel computation, communication, and I/O, ACM Computing Surveys, vol.28, issue.4, 1996. ,
Fast Generation of Random Permutations Via Networks Simulation, Algorithmica, vol.21, issue.1, pp.2-20, 1998. ,
DOI : 10.1007/PL00009206
Efficient external memory algorithms by simulating coarsegrained parallel algorithms, ACM Symposium on Parallel Algorithms and Architectures, pp.106-115, 1997. ,
SSCRAP : An environment for coarse grained algorithms, Fourteenth IASTED International Conference on Parallel and Distributed Computing and Systems, 2002. ,
PRO : a model for parallel resource-optimal computation, 16th Annual International Symposium on High Performance Computing Systems and Applications, pp.106-113, 2002. ,
Randomized fully-scalable BSP techniques for multi-searching and convex hull construction, Proceedings of the eighth annual ACM-SIAM Symposium on Discrete Algorithms, pp.767-776, 1997. ,
Generating random permutations in the framework of parallel coarse grained models, Proceedings of OPODIS'2000, pp.1-16, 2000. ,
Fast parallel generation of random permutations, Automata, Languages and Programming Proceedings of the 18th International Colloquium ICALP'91, pp.405-416, 1991. ,
DOI : 10.1007/3-540-54233-7_151
A complexity theory of efficient parallel algorithms, Theoretical Computer Science, vol.71, issue.1, pp.95-132, 1990. ,
DOI : 10.1016/0304-3975(90)90192-K
An optimal parallel algorithm for integer sorting, 26th Annual Symposium on Foundations of Computer Science (sfcs 1985), pp.496-504, 1985. ,
DOI : 10.1109/SFCS.1985.9
Virtual Laboratories in Probability and Statistics Finite Sampling Models : The Multivariate Hypergeometric Distribution, 2001. ,
A bridging model for parallel computation, Communications of the ACM, vol.33, issue.8, pp.103-111, 1990. ,
Computation of the multivariate hypergeometric distribution function, Computing Science and Statistics, vol.24, pp.25-28, 1992. ,
Efficient sampling from continuous and discrete unimodal distributions, 1994. ,
Campus scientifique, 615 rue du Jardin Botanique Irisa, Campus universitaire de Beaulieu, 35042 RENNES Cedex Unité de recherche INRIA Rhône-Alpes, p.78153, 2004. ,
