New interface
Reports
XML Schema, Tree Logic and Sheaves Automata
Silvano Dal Zilio 1 Denis Lugiez
1 MIMOSA - Migration and mobility : semantics and applications
CRISAM - Inria Sophia Antipolis - Méditerranée , Université de Provence - Aix-Marseille 1, Mines Paris - PSL (École nationale supérieure des mines de Paris)
Abstract : We describe a new class of tree automata, and a related logic on trees, with applications to the processing of XML documents and XML schemas. XML documents, and other forms of semi-structured data, may be roughly described as edge labeled trees. Therefore it is natural to use tree automata to reason on them and try to apply the classical connection between automata, logic and query languages. This approach has been followed by various researchers and has given some notable results, especially when dealing with Document Type Definition (DTD), the simplest standard for defining XML documents validity. But additional work is needed to take into account XML schema, a more advanced standard, for which regular tree automata are not satisfactory. A major reason for this inadequacy is the presence of an associative-commutative operator in the schema language, inherited from the &-operator of SGML, and the inherent limitations of regular tree automata in dealing with associative-commutative algebras. The class of automata considered here, called sheaves automata, is a tailored version of automata for unranked trees with both associative and associative-commutative symbols already proposed by the authors. In order to handle both ordered and unordered operators, we combine the transition relation of regular tree automaton with regular word expression and counting constraints. This extension appears quite natural since, when no counting constraints occurs, we obtain hedge automata, a simple model for XML schemata, and when no constraints occur, we obtain regular tree automata. Building on the classical connection between logic and automata, we also present a decidable tree logic that embeds XML Schema as a plain subset.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071954
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:21:07 PM
Last modification on : Wednesday, October 26, 2022 - 4:00:40 AM
Long-term archiving on: : Tuesday, February 22, 2011 - 12:01:58 PM
Identifiers
  • HAL Id : inria-00071954, version 1
Citation
Silvano Dal Zilio, Denis Lugiez. XML Schema, Tree Logic and Sheaves Automata. RR-4631, INRIA. 2002. ⟨inria-00071954⟩
Share
Metrics
Record views
180
Files downloads
296
