Abstract : We consider traffic grooming in WDM unidirectional rings with all-to-all uniform unitary traffic. We determine the minimum number of SONET/SDH add-drop multiplexers (ADMs) required when the grooming ratio is 3. In fact, using tools of design theory, we solve the equivalent edge partitioning problem: find a partition of the edges of the complete graph on n vertices (K_n) into subgraphs having at most 3 edges and in which the total number of vertices has to be minimized.
