HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Unfolding Of Surfaces
Jean-Marie Morvan 1 Boris Thibert
1 PRISME - Geometry, Algorithms and Robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This paper deals with the approximation of the unfolding of a smooth developpa- ble surface with a triangle mesh. First of all, we give an explicit approximat- ion of the unfolding of a smooth developable surface with the unfolding of a developable triangle mesh close to the smooth surface. The quality of the approximation depends on the maximal angle between the normals of the two surfaces and the relative curvature distance of the smooth surface (which is linked to the curvature of the smooth surface and the Hausdorff distance between the two surfaces). We give examples of sequences of developable triangle meshes inscribed on a sphere of radius 1, with a number of vertices and edges tending to infinity.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071970
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:23:13 PM
Last modification on : Friday, February 4, 2022 - 3:14:57 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:46:52 PM
Identifiers
  • HAL Id : inria-00071970, version 1
Collections
Citation
Jean-Marie Morvan, Boris Thibert. Unfolding Of Surfaces. RR-4615, INRIA. 2002. ⟨inria-00071970⟩
Share
Metrics
Record views
71
Files downloads
649
