Fault Confinement Mechanisms of the CAN Protocol : Analysis and Improvements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Nicolas Navet
  • Fonction : Auteur
  • PersonId : 755790
  • IdRef : 096306831
CAN (Controller Area Network) is a broadcast bus with priority based access to the medium which has become a de-facto standard for data transmissio- n in automotive applications. To prevent a defective node from perturbing the functioning of the whole system, for instance by repetitively sending error frames, the CAN protocol includes fault confinement mechanisms whose objectives are to detect permanent hardware dysfunctioning and to switch off defective nodes. In this study, we derive a Markovian analysis of these mechanisms and identify several shortages. New mechanisms that address theses problems are then proposed and we provide the algorithms for their implementation.
Autre [cs.OH]
RR-4603.pdf (468.9 Ko) Télécharger le fichier
inria-00071982 , version 1 (23-05-2006)
  • HAL Id : inria-00071982 , version 1
Bruno Gaujal, Nicolas Navet. Fault Confinement Mechanisms of the CAN Protocol : Analysis and Improvements. [Research Report] RR-4603, INRIA. 2002. ⟨inria-00071982⟩
174 Consultations
3040 Téléchargements
