Reports
AED: An Accurate and Explicit Loss Differentiation Mechanism
Vijay Arya 1 Thierry Turletti 1
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : In recent years mobile computing has experienced an explosive growth, mainly due to the integration of wireless networks with the wired Internet. To deploy bandwidth-greedy multimedia applications on such heterogeneous environments, efficient congestion control algorithms are required. Indeed, in such a scenario, a packet can cross several wired and wireless links before eventually reaching its destination. When congestion control protocols such as TFRC are used transmit multimedia flows, they need to differentiate between congestion losses and wireless losses to behave correctly and efficiently. Currently proposed end-to-end loss differentiation mechanisms can not reliably predict the differences between congestion and wireless losses. In this paper, we explore explicit loss differentiation. We have designed a simple window framework to explicitly and accurately differentiate these losses. By deploying agents at the boundaries of wireless links, we show that we can efficiently implement our window-based scheme with low overhead. We also point out current limitations of our scheme.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071998
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:30:05 PM
Last modification on : Friday, February 4, 2022 - 3:17:28 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:48:12 PM
Identifiers
  • HAL Id : inria-00071998, version 1
Collections
Citation
Vijay Arya, Thierry Turletti. AED: An Accurate and Explicit Loss Differentiation Mechanism. [Research Report] RR-4587, INRIA. 2002. ⟨inria-00071998⟩
Share
Metrics
Record views
53
Files downloads
106
