Progressive Encoding for Lossless Transmission of 3D Meshes ,
Valence-Driven Connectivity Encoding of 3D Meshes, Eurographics Conference Proceedings, pp.480-489, 2001. ,
Measuring Error on Simplified Surfaces, Computer Graphics Forum, vol.17, issue.2, pp.167-174, 1998. ,
Geometric Compression for Interactive Transmission, Conference Proceedings, pp.319-326, 2000. ,
Surface Simplification Using Quadric Error Metrics, ACM Siggraph Conference Proceedings, pp.209-216, 1997. ,
Real Time Compression of Triangle Mesh Connectivity, ACM Siggraph Conference Proceedings, pp.133-140, 1998. ,
Face fixer: Compressing polygon meshes with properties, ACM SIGGRAPH 2000 Conference Proceedings, pp.263-270, 2000. ,
Near-Optimal Connectivity Encoding of 2-Manifold Polygon Meshes, The Journal of Graphical Models/special issue, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072013
Guaranteed 3.67v bit encoding of planar triangle graphs, 11th Canadian Conference on Computational Geometry, pp.146-149, 1999. ,
Connectivity compression for irregular quadrilateral meshes, 1999. ,
Optimized triangle mesh compression using prediction trees, Proceedings of 8th Pacific Graphics, 2000. ,
Vertex data compression for triangle meshes, Proceedings of the 8th Pacific Graphics Conference on Computer Graphics and Application, pp.225-234, 2000. ,
Connectivity Compression for Triangle Meshes, IEEE Transactions on Visualization and Computer Graphics, 1999. ,
Wrap& zip decompression of the connectivity of triangle meshes compressed with EdgeBreaker, Journal of Computational Geometry Theory and Applications, vol.14, 1999. ,
Triangle Mesh Compression, Graphics Interface 98 Conference Proceedings, pp.26-34, 1998. ,
Arithmetic Coding for Data Compression, Communications of the ACM, vol.30, issue.6, pp.520-540, 1987. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38330 Montbonnot-St, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
