HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Linear stability analysis in fluid-structure interaction with transpiration. Part I: formulation and mathematical analysis
Abstract : The aim of this work is to provide a new Linearization Principle approach particularly suited for problems in fluid-structure stability. The complexity here, and the main difference with respect to the classical approach, comes from the fact that the full non-linear fluid equations are written in a moving (i.e. time dependent) domain. The underlying idea of our approach comes from the linearization-transpiration method developed in [11,12]. This allows us to obtain a new coupled spectral problem involving the linearized Navier-Stokes equations and those of a reduced linear structure. The coupling is realized through specific transpiration conditions on a fixed interface, while keeping a fixed fluid domain. Finally, we provide a first rigorous mathematical treatment of this eigenproblem.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072018
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:34:41 PM
Last modification on : Friday, February 4, 2022 - 3:08:18 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:49:06 PM
Identifiers
  • HAL Id : inria-00072018, version 1
Collections
Citation
Miguel Angel Fernández, Patrick Le Tallec. Linear stability analysis in fluid-structure interaction with transpiration. Part I: formulation and mathematical analysis. [Research Report] RR-4570, INRIA. 2002. ⟨inria-00072018⟩
Share
Metrics
Record views
175
Files downloads
206
