Abstract : This short paper is devoted to the study of effective hardware architectures for the RC6 block cipher using Virtex-E and Virtex-II FPGA devices. The key point of the implementation is the design of an arithmetic operator computing f(X)=(X(2X+1))2^w. Significant speed and area improvements are obtained by taking full advantage of the small multiplier blocks available in Virtex-II devices.
