HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Impact of Mixed--Parallelism on Parallel Implementations of Strassen and Winograd Matrix Multiplication Algorithms
Frédéric Desprez 1 Frédéric Suter 1
1 REMAP - Regularity and massive parallel computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : In this paper we study the impact of the simultaneous exploitation of data-- and task--parallelism on Strassen and Winograd matrix multiplication algorithms. We present two mixed--parallel implementations. The former follows the phases of the original algorithms while the latter has been designed as the result of a list scheduling algorithm. We give a theoretical comparison- , in terms of memory usage and execution time, between our algorithms and classical data--parallel implementations. This analysis is corroborated by experiments. Finally we give some hints about an heterogeneous version of our algorithms.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072106
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:48:24 PM
Last modification on : Friday, February 4, 2022 - 3:14:51 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:53:31 PM
Identifiers
  • HAL Id : inria-00072106, version 1
Collections
Citation
Frédéric Desprez, Frédéric Suter. Impact of Mixed--Parallelism on Parallel Implementations of Strassen and Winograd Matrix Multiplication Algorithms. [Research Report] RR-4482, INRIA. 2002. ⟨inria-00072106⟩
Share
Metrics
Record views
92
Files downloads
251
