Priority queueing with finite buffer size and randomized push-out mechanism
The non-preemptive priority queueing with a finite buffer is considered. We introduce a randomized push-out buffer management mechanism which allows to control very efficiently the loss probability of priority packets. The packet loss probabilities for priority and non-priority traffic are calculated using the generating function approach. For the particular case of the standard non-randomized push-out scheme we obtain explicit analytic expressions. The theoretical results are illustrated by a numerical example.
Autre [cs.OH]
