HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Quality Assessment of Electromagnetic Localizers in the Context of 3D Ultrasound
François Rousseau 1 Christian Barillot 1
1 VISTA - Vision spatio-temporelle et active
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : Electromagnetic spatial localizers represent low cost and flexible solution for clinical free-hand three dimensional ultrasound system. Their performances condition the accuracy of the calibration and the ultrasound reconstructed volume and the robustness of the acquisition stage. In this study, we evaluate the resolution and the accuracy for translations and rotations of two widespread localizers in quite metallic environment: Fastrak and Flock of Bird. Our experiments show that their resolution for position is under 0.2mm at 60cm, and their resolution for orientation is around 0.06 degrees. For translations below 30cm, their position accuracy is around 1.5mm, and the angular accuracy is under 1 degree. These results show that theses devices provide sufficient accuracy for use in a clinical context.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072180
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 7:58:57 PM
Last modification on : Friday, February 4, 2022 - 3:24:01 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:57:09 PM
Identifiers
  • HAL Id : inria-00072180, version 1
Citation
François Rousseau, Christian Barillot. Quality Assessment of Electromagnetic Localizers in the Context of 3D Ultrasound. [Research Report] RR-4408, INRIA. 2002. ⟨inria-00072180⟩
Share
Metrics
Record views
103
Files downloads
101
