Extended Kantorovich norms : a tool for optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Kevin Guittet
  • Fonction : Auteur
  • PersonId : 958305
In this paper, we focus on extended Kantorovich norms, which seem to be much more flexible than many other «metrics» deriving from optimal mass transport problems. General theoretical results are recalled, and the discrete case is investigated, especially from a computational point of view. An efficient algorithm is then introduced to solve the related linear programming problem, and possible applications are discussed.
Autre [cs.OH]
RR-4402.pdf (345.47 Ko) Télécharger le fichier
inria-00072186 , version 1 (23-05-2006)
  • HAL Id : inria-00072186 , version 1
Kevin Guittet. Extended Kantorovich norms : a tool for optimization. [Research Report] RR-4402, INRIA. 2002. ⟨inria-00072186⟩
444 Consultations
835 Téléchargements
