New interface
Reports
Reverse Automatic Differentiation for Optimum Design: from Adjoint State Assembly to Gradient Computation
F. Courty 1 Alain Dervieux B. Koobus L. Hascoet
1 TROPICS - Program transformations for scientific computing
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : The utilization of reverse mode Automatic Differentiation to the adjoint method for solving an Optimal Design problem is described. Using the reverse mode, we obtain the adjoint system residual in a rather efficient way. But memory requirements may be very large. The family of programs to differentiate involves many independant calculations, typically in parallel loops. Then we propose to apply a reverse differentiation «by iteration». This demands much less memory storage. This methods is used for the computing of the adjoint state and gradient related to the Optimal Design problem.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072225
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 8:09:32 PM
Last modification on : Friday, February 4, 2022 - 3:15:38 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:05:57 PM
Identifiers
  • HAL Id : inria-00072225, version 1
Collections
Citation
F. Courty, Alain Dervieux, B. Koobus, L. Hascoet. Reverse Automatic Differentiation for Optimum Design: from Adjoint State Assembly to Gradient Computation. RR-4363, INRIA. 2002. ⟨inria-00072225⟩
Share
Metrics
Record views
70
Files downloads
394
