Abstract : In this paper, interval arithmetic using an underlying multiple precision arithmetic is briefly presented. Then interval Newton iteration for solving nonlinear equations is introduced. A new Newton's algorithm based on multiple precision interval arithmetic is given, along with its properties: termination- , arbitrary accuracy on the computed zeros, automatic and dynamic adaptation of the precision. Finally some experiments illustrate the behaviour of this method.
