Generic Program Monitoring by Trace Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Erwan Jahier
Mireille Ducassé
Program execution monitoring consists of checking whole executions for given properties in order to collect global run-time information. Monitoring is very useful to maintain programs. However, application developers face the following dilemma: either they use existing tools which never exactly fit their needs, or they invest a lot of effort to implement monitoring code. In this report we argue that, when an event-oriented tracer exists, the compiler developers can enable the application developers to easily code their own, relevant, monitors. We propose a high-level operator, called foldt, which operates on execution traces. One of the key advantages of our approach is that it allows a clean separation of concerns; the definition of monitors is totally distinct from both the user source code and the language compiler. We give a number of applications of the foldt operator to compute monitors for Mercury program executions: execution profiles, graphical abstract views, and two test coverage measurements. Each example is implemented by a few simple lines of Mercury.
RR-4323.pdf (422.75 Ko) Télécharger le fichier
inria-00072264 , version 1 (23-05-2006)
  • HAL Id : inria-00072264 , version 1
Erwan Jahier, Mireille Ducassé. Generic Program Monitoring by Trace Analysis. [Research Report] RR-4323, INRIA. 2001. ⟨inria-00072264⟩
113 Consultations
257 Téléchargements
