TCP Modeling in the Presence of Nonlinear Window Growth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Konstantin Avrachenkov
Chadi Barakat
Rudesindo Nuñez-Queija
  • Fonction : Auteur
We develop a model for TCP that accounts for both sublinearity and limitation of window increase. Sublinear window growth is observed when the round-trip time of the connection increases with the window size. The limitation is due to the window advertised by the receiver. First, we derive the required conditions for the stability of the model. Then, we write the Kolmogorov equation under Markovian assumptions. The model is solved 1analytic- ally for some particular cases. A good match between the throughput predicted by the model and the throughput measured on real TCP connections is reported.
Autre [cs.OH]
RR-4312.pdf (549.77 Ko) Télécharger le fichier
inria-00072275 , version 1 (23-05-2006)
  • HAL Id : inria-00072275 , version 1
Eitan Altman, Konstantin Avrachenkov, Chadi Barakat, Rudesindo Nuñez-Queija. TCP Modeling in the Presence of Nonlinear Window Growth. RR-4312, INRIA. 2001. ⟨inria-00072275⟩
68 Consultations
428 Téléchargements
