Practical Stabilization of Driftless Systems on Lie Groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Claude Samson
A general control design approach for the stabilization of controllable driftless nonlinear systems on finite dimensional Lie groups is presented. The approach is based on the concept of transverse functions, the existence of which is equivalent to the system's controllability. Its outcome is the practical stabilization of any trajectory -i.e. not necessarily a solution of the control system--- in the state space. The possibility of applying the approach to an arbitrary controllable smooth driftless system follows in turn from the fact that any controllable homogeneous approximation of this system can be lifted (via a dynamic extension) to a system on a Lie group. Illustrative examples are given.
Autre [cs.OH]
RR-4294.pdf (329.09 Ko) Télécharger le fichier
inria-00072293 , version 1 (23-05-2006)
  • HAL Id : inria-00072293 , version 1
Pascal Morin, Claude Samson. Practical Stabilization of Driftless Systems on Lie Groups. RR-4294, INRIA. 2001. ⟨inria-00072293⟩
89 Consultations
210 Téléchargements
