HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
An Esterel-based Development Environment for Designing Software Radio Applications
Hahnsang Kim 1 Thierry Turletti 1
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Designing DSP (Digital Signal Processing) applications is a complex task. It requires a software development environment capable of putting together DSP modules and providing facilities to debug, verify and validate the code. Pspectra is one of the first toolkits available to design basic software radio applications on standard PC workstations. In this report, we present the Esterel extensions we have added to this toolkit in order to make the debugging and verification phases of development easier. These phases are known to be the most time consuming operations. In order to improve the performance of these applications, we have also implemented a new scheduling model which is well suited to the specification of the control part of the applications in Esterel. The performance results reported in the report are promising.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00072332
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 8:25:12 PM
Last modification on : Friday, February 4, 2022 - 3:17:19 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:04:04 PM
Identifiers
  • HAL Id : inria-00072332, version 1
Collections
Citation
Hahnsang Kim, Thierry Turletti. An Esterel-based Development Environment for Designing Software Radio Applications. [Research Report] RR-4256, INRIA. 2001. ⟨inria-00072332⟩
Share
Metrics
Record views
67
Files downloads
147
