Global Adaptive Observer for a Class of Nonlinear Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Qinghua Zhang
  • Fonction : Auteur
  • PersonId : 830741
The problem considered in this report is the joint estimation of state and some parameters for a class of truly nonlinear systems. The proposed method is constructive and garantees global convergence. It has been inspired by the technique of high gain observer and by a recent result on linear adaptive observer. A numerical example is presented for illustration. Potential applications of the adaptive observer arc adaptive control fault detection and isolation.
RR-4246.pdf (210.77 Ko) Télécharger le fichier
inria-00072341 , version 1 (23-05-2006)
  • HAL Id : inria-00072341 , version 1
Qinghua Zhang, Aiping Xu. Global Adaptive Observer for a Class of Nonlinear Systems. [Research Report] RR-4246, INRIA. 2001. ⟨inria-00072341⟩
159 Consultations
247 Téléchargements
