Reports
EASEA : un langage de spécification pour les algorithmes évolutionnaires
Abstract : Evolutionary algorithms are not straightforward to implement and the lack of any specialised language forces users to write their algorithms in C, C++ or JAVA. However, most evolutionary algorithms follow a similar design, and the only really specific part is the code representing the problem to be solved. Therefore, it seems that nothing, in theory, could prevent a user from being able to design and run his evolutionary algorithm from a Graphic User Interface, without any other programming effort than the function to be optimised. Writing such a GUI rapidly poses the problem of saving and reloading the evolutionary algorithm on which the user is working, and translating the information into compilable code. This very much sounds like a specifying language and its compiler. The EASEA software was created on this purpose, and to our knowledge, it is the first and only usable compiler of a language specific to evolutionary algorithms. This reprot describes how EASEA has been designed and the problems which needed to be solved to achieve its implementation.
Document type :
Reports
Complete list of metadatas
https://hal.inria.fr/inria-00000849
Contributor : Marc Schoenauer <>
Submitted on : Thursday, November 24, 2005 - 4:26:05 PM
Last modification on : Thursday, March 5, 2020 - 6:25:29 PM
Document(s) archivé(s) le : Friday, April 2, 2010 - 11:09:43 PM
Identifiers
  • HAL Id : inria-00000849, version 1
Collections
Citation
Pierre Collet, Marc Schoenauer, Evelyne Lutton, Jean Louchet. EASEA : un langage de spécification pour les algorithmes évolutionnaires. [Research Report] RR-4218, INRIA. 2001, pp.17. ⟨inria-00000849⟩
Share
Metrics
Record views
458
Files downloads
920
