Abstract : We study the stability of the optimal filter w.r.t. its initial condition and w.r.t. the model for the hidden state and the observations in a general hidden Markov model, using the Hilbert projective metric. These stability results are then used to prove, under some mixing assumption, the uniform convergence to the optimal filter of several particle filters, such as the interacting particle filter and other original particle filters.
