New interface
Reports (Research report)
Calibration of Digital Amateur Cameras
Magdalena Urbanek 1 Radu Horaud 1 Peter Sturm 1
1 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : We introduce a novel outlook on the self-calibration task, by considering images taken by a camera in motion, allowing for zooming and focusing. Apart from the complex relationship between the lens control settings and the intrinsic camera parameters, a prior off-line calibration allows to neglect the setting of focus, and to fix the principal point and aspect ratio throughout distinct views. Thus, the calibration matrix is dependent only on the zoom position. Given a fully calibrated reference view, one has only one parameter to estimate for any other view of the same scene, in order to calibrate it and to be able to perform metric reconstructions. We provide a close-form solution, and validate the reliability of the algorithm with experiments on real images. An important advantage of our method is a reduced - to one - number of critical camera configurations, associated with it. Moreover, we propose a method for computing the epipolar geometry of two views, taken from different positions and with different (spatial) resolutions; the idea is to take an appropriate third view, that is "easy" to match with the other two.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00072405
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 9:52:37 AM
Last modification on : Thursday, October 27, 2022 - 4:02:27 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:06:19 PM
Identifiers
  • HAL Id : inria-00072405, version 1
Citation
Magdalena Urbanek, Radu Horaud, Peter Sturm. Calibration of Digital Amateur Cameras. [Research Report] RR-4214, INRIA. 2001. ⟨inria-00072405⟩
Share
Metrics
Record views
141
Files downloads
163
