Building Detection by Markov Object processes and a MCMC Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Xavier Descombes
Josiane Zerubia
  • Fonction : Auteur
  • PersonId : 833424
Hervé Le Men
  • Fonction : Auteur
This work aims at detecting buildings in digital a­erial photographs. Here we model a set of buildings by a configuration of objects. We define a point process on the set of configurations, which splits into two parts : the first one is a prior model on the configurations which use interactions between objects, the second one is a data model which enforces the coherence with the image. Thus we have a posterior distribution whose maximum has to be found. In order to achieve this maximum, we use a MCMC simulation - a Metropolis-Hasting- s-Green algorithm - mixed with a simulated annealing. Then we test this method on both synthetic and real stereo-images.
Autre [cs.OH]
RR-4206.pdf (614.95 Ko) Télécharger le fichier
inria-00072416 , version 1 (24-05-2006)
  • HAL Id : inria-00072416 , version 1
Laurent Garcin, Xavier Descombes, Josiane Zerubia, Hervé Le Men. Building Detection by Markov Object processes and a MCMC Algorithm. RR-4206, INRIA. 2001. ⟨inria-00072416⟩
118 Consultations
146 Téléchargements
