Large Deviations Problems for Star Networks: the Min Policy Part I: Finite Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
In this paper, we prove a sample path large deviation principle for a rescaled process $n^{-1}Q_{nt}$, where $Q_t$ represents the joint number of connections at time $t$ in a star network where the bandwidth is shared between customers according to the so-called min policy. The rate function is computed explicitly. One of the main steps consists in deriving large deviation bounds for an empirical generator constructed from the join number of customers and arrivals on each route. The rest of the analysis relies on a suitable change of measure together with a localization procedure.
RR-4143.pdf (561.2 Ko) Télécharger le fichier
inria-00072481 , version 1 (24-05-2006)
  • HAL Id : inria-00072481 , version 1
Franck Delcoigne, Arnaud de La Fortelle. Large Deviations Problems for Star Networks: the Min Policy Part I: Finite Time. [Research Report] RR-4143, INRIA. 2001. ⟨inria-00072481⟩
94 Consultations
87 Téléchargements
