HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Stability Analysis of Second Order Fluid Flow Models with State-Dependent Parameters
Landy Rabehasaina 1 Bruno Sericola 1
1 ARMOR - Architectures and network models
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes, Ecole Nationale Supérieure des Télécommunications de Bretagne
Abstract : We study in this paper the stability of a fluid queue with an infinite capacity buffer. The input and service rates are governed by a general stochastic process and are allowed to depend on the fluid level in the buffer. The variability of the traffic is modeled by a Brownian motion and a local variance function which also depends on the fluid level in the buffer. The behavior of this second order fluid flow model is described by a reflected stochastic differential equation and, under stationarity and ergodicity assumptions, we obtain stability conditions for this general fluid queue.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072494
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 10:07:32 AM
Last modification on : Friday, February 4, 2022 - 3:23:21 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:10:23 PM
Identifiers
  • HAL Id : inria-00072494, version 1
Citation
Landy Rabehasaina, Bruno Sericola. Stability Analysis of Second Order Fluid Flow Models with State-Dependent Parameters. [Research Report] RR-4133, INRIA. 2001. ⟨inria-00072494⟩
Share
Metrics
Record views
85
Files downloads
147
