Stack Algorithms at High Loads : Analysis of Unfairness or Singular Behaviours - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Cédric Adjih
Philippe Jacquet
Paul Mühlethaler
  • Fonction : Auteur
  • PersonId : 833453
In this paper, we investigate the fairness of stack access algorithms in overload conditions. We show that conventional Last In First Out free-acces- s stack algorithms provide unfair channel access at high loads. A subset of end-users may starve during network overloads as the other nodes capture the whole channel capacity. We show that the First In First Out free-access stack protocol can cope with this unfairness problem. The blocked access stack algorithms are not showing unfairness problems.
RR-4130.pdf (188.83 Ko) Télécharger le fichier
inria-00072498 , version 1 (24-05-2006)
  • HAL Id : inria-00072498 , version 1
Cédric Adjih, Philippe Jacquet, Paul Mühlethaler. Stack Algorithms at High Loads : Analysis of Unfairness or Singular Behaviours. [Research Report] RR-4130, INRIA. 2001. ⟨inria-00072498⟩
110 Consultations
110 Téléchargements
