Lyapunov Equation for the Stability of Linear Delay Systems of Retarded and Neutral Type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
In this note is studied the delay-independent stability of delay systems. It is shown that the strong delay-independent stability is tantamount to the feasibility of certain linear matrix inequality, or equivalently to the existence of certain quadratic Lyapunov-Krasovskii functional, independent of the (nonnegative) value of the delay. This constitutes the analogue of some well-known properties of finite-dimensional systems. This result is then applied to study delay-independent stability of systems with commensurate delays, delay-independent stabilizability, and delay-indepen- dent stability of systems with polytopic uncertainties.
RR-4127.pdf (292.08 Ko) Télécharger le fichier
inria-00072501 , version 1 (24-05-2006)
  • HAL Id : inria-00072501 , version 1
Pierre-Alexandre Bliman. Lyapunov Equation for the Stability of Linear Delay Systems of Retarded and Neutral Type. [Research Report] RR-4127, INRIA. 2001. ⟨inria-00072501⟩
77 Consultations
583 Téléchargements
