On a Convolution Operator Arising in a Double Porosity Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Contaminant transport in a fractured porous medium can be modeled, under appropriate conditions, with a double porosity model. Such a model consists of a parabolic equation with a coupling term describing contaminant exchange between the fractures, which have high permeability, and the matrix block, which has low permeability. Interpreting the coupling term as an operator, pseudo-differential in time, we obtain a method for calculating this term which is rapid in comparison with standard discretization methods.
Autre [cs.OH]
RR-4126.pdf (234.46 Ko) Télécharger le fichier
inria-00072502 , version 1 (24-05-2006)
  • HAL Id : inria-00072502 , version 1
Clarisse Alboin, Jérôme Jaffré, Patrick Joly, Jean Roberts. On a Convolution Operator Arising in a Double Porosity Model. [Research Report] RR-4126, INRIA. 2001. ⟨inria-00072502⟩
164 Consultations
79 Téléchargements
