Reports
Perturbation of Multivariable Linear Quadratic Systems with Jump Parameters and Hybrid Controls
Abstract : We consider the problem of the perturbation of a class of linear-quadratic systems where the change from one structure (for the dynamics and costs) to another are governed by a finite-state Markov process where the transition are perturbed. The problem above lead to the analysis of some perturbed linearly coupled set of quadratic equations (Riccati Equation). We show that the matrix obtained as the solution of the equations, which determine the optimal value and control, has Taylor expansion in the perturbation parameter. We compute explicitly the term of this expansion.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00072505
Contributor : Rapport de Recherche Inria <>
Submitted on : Wednesday, May 24, 2006 - 10:08:55 AM
Last modification on : Friday, June 7, 2019 - 10:08:14 PM
Long-term archiving on: : Sunday, April 4, 2010 - 11:10:48 PM
Identifiers
  • HAL Id : inria-00072505, version 1
Collections
Citation
Rachid El-Azouzi, Mohammed Abbad, Eitan Altman. Perturbation of Multivariable Linear Quadratic Systems with Jump Parameters and Hybrid Controls. RR-4123, INRIA. 2001. ⟨inria-00072505⟩
Share
Metrics
Record views
313
Files downloads
472
