Framing Protocols on Upstream Channel in CATV Networks: Asymptotic Average Delay Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Philippe Jacquet
Paul Mühlethaler
  • Fonction : Auteur
  • PersonId : 833453
Philippe Robert
This paper deals with bandwidth management of the upstream channel of a CATV network. The upstream channel bandwidth must be splitted between random access and reserved access. This splitting is obtained via a framing protocol. This framing may be «explicit» i.e. defined by special control signals or «implicit» i.e. defined by the reservation scheme. We describe in details four framing management schemes of the upstream channel. We then study these framing management schemes with simple analytical models.An asymptotic average access delay analysis (when the propagation is large) is provided. As a result of our models, we show that implicit framing outperforms explicit framing schemes.
RR-4114.pdf (219.23 Ko) Télécharger le fichier
inria-00072517 , version 1 (24-05-2006)
  • HAL Id : inria-00072517 , version 1
Philippe Jacquet, Paul Mühlethaler, Philippe Robert. Framing Protocols on Upstream Channel in CATV Networks: Asymptotic Average Delay Analysis. [Research Report] RR-4114, INRIA. 2001. ⟨inria-00072517⟩
143 Consultations
70 Téléchargements
