HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Non-Linear Anisotropic Elasticity for Real-Time Surgery Simulation
Guillaume Picinbono 1 Hervé Delingette 1 Nicholas Ayache 1
1 EPIDAURE - Medical imaging and robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : In this article, we describe the latest developments of the minimally invasive hepatic surgery simulator prototype developed at INRIA. A key problem with such a simulator is the physical modeling of soft tissues. We propose a new deformable model based on non-linear elasticity, anisotropic behavior, and the finite element method. This model is valid for large displacements, which means in particular that it is invariant with respect to rotations. This property improves the realism of the deformations and solves the problems related to the shortcomings of linear elasticity, which is only valid for small displacements. We also address the problem of volume variations by adding to our model incompressibility constraints. Finally, we demonstrate the relevance of this approach for the real-time simulation of laparoscopic surgical gestures on the liver.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072611
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 10:23:54 AM
Last modification on : Friday, February 4, 2022 - 3:18:26 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:15:18 PM
Identifiers
  • HAL Id : inria-00072611, version 1
Collections
Citation
Guillaume Picinbono, Hervé Delingette, Nicholas Ayache. Non-Linear Anisotropic Elasticity for Real-Time Surgery Simulation. [Research Report] RR-4028, INRIA. 2000, pp.21. ⟨inria-00072611⟩
Share
Metrics
Record views
122
Files downloads
594
