New interface
Reports (Research report)
Dense Fluid Flow Estimation
Thomas Corpetti 1 Etienne Mémin 1 Patrick Pérez 2
1 VISTA - Vision spatio-temporelle et active
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : In this paper we address the problem of estimating and analyzing the motion in image sequences showing fluid phenomenon. Due to the great deal of spatial and temporal distortions that luminance patterns exhibit in images of fluid, standard techniques from Computer Vision, originally designed for quasi-rigid motions with stable salient features, are not well adapted in this context. In that prospect, we investigate a dedicated energy-based motion estimator. The considered functional includes an original data model relying on the continuity equation of fluid mechanics. This new data model, which is specifically designed to be embedded in a multiresolution framework, is associated to an original div-curl type regularization. The optimization of the global energy function is solved within an efficient multigrid scheme. The performances of the resulting fluid flow estimator are demonstrated both on synthetic and real (meteorological) image sequences.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00072634
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 10:27:43 AM
Last modification on : Friday, November 18, 2022 - 9:23:25 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:16:26 PM
Identifiers
  • HAL Id : inria-00072634, version 1
Citation
Thomas Corpetti, Etienne Mémin, Patrick Pérez. Dense Fluid Flow Estimation. [Research Report] RR-4009, INRIA. 2000. ⟨inria-00072634⟩
Share
Metrics
Record views
88
Files downloads
134
