Multi-Valued Computer Algebra
Abstract : One of the main strengths of computer algebra is being able to solve a family of problems with one computation. In order to express not only one problem but a family of problems, one introduces some symbols which are in fact the parameters common to all the problems of the family. The user must be able to understand in which way these parameters affect the result when he looks at the answer. Otherwise it may lead to completely wrong calculations, which when used for numerical applications bring nonsensical answers. This is the case in most current Computer Algebra Systems we know because the form of the answer is never explicitly conditioned by the values of the parameters. The user is not even informed that the given answer may be wrong in some cases then computer algebra systems can not be entirely trustworthy. We have introduced multi-valued expressions called conditional expressions, in which each potential value is associated with a condition on some parameters. This is used, in particular, to capture the situation in integration, where the form of the answer can depend on whether certain quantities are positive, negative or zero. We show that it is also necessary when solving modular linear equations or deducing congruence conditions from complex expressions.
Type de document :
Rapport
[Research Report] RR-4001, INRIA. 2000, pp.36
Liste complète des métadonnées
https://hal.inria.fr/inria-00072643
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 10:29:13
Dernière modification le : jeudi 11 janvier 2018 - 15:49:37
Document(s) archivé(s) le : dimanche 4 avril 2010 - 23:16:45
Fichiers
  • HAL Id : inria-00072643, version 1
Collections
Citation
Christèle Faure, James Davenport, Hanane Naciri. Multi-Valued Computer Algebra. [Research Report] RR-4001, INRIA. 2000, pp.36. 〈inria-00072643〉
Métriques
Consultations de la notice
147
Téléchargements de fichiers
193
