New interface
Reports (Research report)
Automatic- versus Manual- differentiation for non-linear inverse modeling
Abstract : Emerging tools for automatic differentiation (AD) of computer programs should be of great benefit for the implementation of many derivative-based numerical methods such as those used for inverse modeling. The Odyssée software, one such tool for Fortran 77 codes, has been tested on a sample model that solves a 2D non-linear diffusion-type equation. Odyssée offers both the forward and the reverse differentiation modes, that produce the tangent and the cotangent models, respectively. The two modes have been implemented on the sample application. A comparison is made with a manually-pr- oduced differentiated code for this model (MD), obtained by solving the adjoint equations associated with the model's discrete state equations. Following a presentation of the methods and tools and of their relative advantages and drawbacks, the performances of the codes produced by the manual and automatic methods are compared, in terms of accuracy and of computing efficiency (CPU and memory needs). The perturbation method (finite-difference approximation of derivatives) is also used as a reference. Based on the test of Taylor, the accuracy of the two AD modes proves to be excellent and as high as machine precision permits, a strong indication of Odyssée's capability to produce error-free codes. Comparatively, the manually-produced derivatives (MD) sometimes appear to be slightly biased, which is likely due to the fact that a theoretical model (state equations) and a practical model (computer program) do not exactly coincide, while the accuracy of the perturbation method is very uncertain. The MD code largely outperforms all other methods in computing efficiency, a matter of current research for the improvement of AD tools. It is reckoned though that such tools can already be of considerable help for the computer implementation of many numerical methods, avoiding the tedious task of hand-coding the different- iation of complex algorithms.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00072666
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 10:32:20 AM
Last modification on : Wednesday, October 26, 2022 - 8:14:17 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:17:27 PM
Identifiers
Citation
David Elizondo, Christèle Faure, Bernard Cappelaere. Automatic- versus Manual- differentiation for non-linear inverse modeling. [Research Report] RR-3981, INRIA. 2000, pp.41. ⟨inria-00072666⟩
Share
Metrics
Record views
193
Files downloads
508
