Stochastic Localization of Instability and Deterministic Enhancement of Accuracy for Iterative Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2000
Philippe Langlois
Finite precision computations may affect the stability of iterative algorithms and the accuracy of computed solutions. Automatic approaches are proposed to control these effects as for example, the CESTAC and the CENA methods. We focus here on a complementary use of these two methods to localize unstable behavior of the algorithm, improve its stability and the accuracy of the solutions. We present computational experiments on ill-conditioned polynomial roots approximated with Newton's iteration.
RR-3966.pdf (215.95 Ko) Télécharger le fichier
inria-00072682 , version 1 (24-05-2006)
  • HAL Id : inria-00072682 , version 1
Philippe Langlois. Stochastic Localization of Instability and Deterministic Enhancement of Accuracy for Iterative Algorithms. RR-3966, INRIA. 2000. ⟨inria-00072682⟩
105 Consultations
101 Téléchargements
