Overhead in Mobile Ad-hoc Network Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Philippe Jacquet
Laurent Viennot
The present note proposes a survey of protocol overheads in mobile ad-hoc networks. An analysis is proposed to estimate overhead due to control packets. An analysis and simulations are proposed to estimate overhead due to non-optimality of the routes constructed by some protocols.
Autre [cs.OH]
RR-3965.pdf (284.56 Ko) Télécharger le fichier
inria-00072683 , version 1 (24-05-2006)
  • HAL Id : inria-00072683 , version 1
Philippe Jacquet, Laurent Viennot. Overhead in Mobile Ad-hoc Network Protocols. [Research Report] RR-3965, INRIA. 2000. ⟨inria-00072683⟩
152 Consultations
2936 Téléchargements
