HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Verification of a Sliding Window Protocol Using IOA and MONA
Mark Smith 1 Nils Klarlund 2
1 SIGMA2 - Signal, models, algorithms
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : We show how to use a decision procedure for WS1S (the MONA tool) to give automated correctness proofs of a sliding window protocol under assumptions of unbounded window sizes, buffer sizes, and channel capacities. We also verify a version of the protocol where the window size is fixed. Since our mechanized target logic is WS1S, not the finite structures of traditional model checking, our method employs only two easy reductions outside the decidable framework. Additionally, we formulate invariants that describe the reachable global states, but the bulk of the detailed reasoning is left to the decision procedure. Because the notation of WS1S is too low-level to describe complicated protocols at a reasonable level of abstraction, we use a higher level language for the protocol description, and then build a tool that automatically translates this language to the MONA syntax. The higher level language we use is IOA. It is a language for distributed programming and is based on Input/Output Automata.
Document type :
Reports
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/inria-00072689
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 10:36:07 AM
Last modification on : Friday, February 4, 2022 - 3:15:20 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:18:37 PM
Identifiers
  • HAL Id : inria-00072689, version 1
Citation
Mark Smith, Nils Klarlund. Verification of a Sliding Window Protocol Using IOA and MONA. [Research Report] RR-3959, INRIA. 2000. ⟨inria-00072689⟩
Share
Metrics
Record views
113
Files downloads
342
