Pajé, an Extensible and Interactive and Scalable Environment for Visualizing Parallel Program Executions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
This report describes Pajé, an interactive visualization tool for displaying the execution of parallel applications where a (potentially) large number of communicating threads of various life-times execute on each node of a distributed memory parallel system. Pajé is capable of representing a wide variety of interactions between threads. The main novelty of Pajé is an original combination of three of the most desirable properties of visualization tools for parallel programs: extensibility, interactivity and scalability. Interactivity gives the possibility to inspect all the objects displayed in the current screen and to move back and forth in time. Scalability is the ability to cope with long computations involving a large number of threads. Extensibility gives the possibility to extend easily the environment with new functionalities. The interactivity and scalability of Pajé are exemplified by the performance tuning of a molecular dynamics application. To be easier to extend, Pajé was designed as a data-flow graph of modular components, most of them being independent of the semantics of the programming model of the visualized parallel programs. In addition, the genericity of the main components of Pajé allow application programmers to adapt the visualization to their needs, without having to know any insight nor to modify any component of Pajé.
RR-3919.pdf (608.23 Ko) Télécharger le fichier
inria-00072734 , version 1 (24-05-2006)
  • HAL Id : inria-00072734 , version 1
Jacques Chassin de Kergommeaux, Benhur De Oliveira Stein. Pajé, an Extensible and Interactive and Scalable Environment for Visualizing Parallel Program Executions. [Research Report] RR-3919, INRIA. 2000. ⟨inria-00072734⟩
196 Consultations
301 Téléchargements
